Bursma
May 10, 2005, 2:55 PM
Post #4 of 4
(2110 views)
A TV viewing yagi antenna just for a specific UHF channel? I haven't heard of such a beast, nor would I know how a channel specific antenna is different from a genneral UHF yagi (if you know, please let me know). What I can tell you is that channel 48's frequency band is 674-680 MHz. The picture Carrier is 675.25, the color carrier is 677.579, and the sound carrier is 678.5. You will also want to know how long a distance you want to recieve the signal. I can tell you an outdoor UHF/VHF antenna with a range of 30 miles would cost around $40, probably below that. A UHF yagi would probably run under $75. Good luck. If you want to actually buy one, I might be able to help you out.
