Dec 31, 2005, 4:11 AM
Post #3 of 3
(3044 views)
Yup agree with that, chances are the thing is lit and thats not the fault. Getting a reading on AC on that is dependant on your meter, only better grade meters can give accurate readings of voltage at scan frequencies. Pull the tube base off and ohms read the pins as stated, if OK read the tube base across the socket, if thats OK move on to reading Grid and cathode voltages.
