ctc 169
need help1
Mar 31, 2011, 9:44 PM
Post #1 of 12 (1924 views)
ctc 169 Can't Post
Working on ctc169bg5 32in picture tube type goes on and off 3 times can hear high voltage come on then shut down have checked al the usual suspect cap around the hot and in the power supply all ck good. any suggestions will be helpfull. thank you
Mar 31, 2011, 11:20 PM
Post #2 of 12 (1919 views)
Re: [need help1] ctc 169 [In reply to] Can't Post
need help1;.....
Have you checked B+ to the HOT ????
IF you did not & you do , UNSOLDER the HOT & REMOVE it BEFORE you read the voltage...
If you don't , you can/will blow your meter....
You have a manual ???
How did you check the caps ???
Post results....
Later...Ron.M....Cool....
need help1
Apr 1, 2011, 12:18 AM
Post #3 of 12 (1913 views)
Re: [Ron.M] ctc 169 [In reply to] Can't Post
I used a capacitance meter the kind that you have to remove the caps from the board they all checked perfect which was a surprise considering how old the set is will ck voltage tomorrow. thanks
Apr 1, 2011, 1:33 AM
Post #4 of 12 (1910 views)
need help1;....
Have you got & know how to use an ESR meter ???....
Also;,"You have a manual ???"...Yes no ???
Can you provide a list of the caps you checked ????
I have good reasons for needing this info....
PLEASE answer ALL my questions....THANKS....Sly....
Later....Ron.M....Cool....
need help1
Apr 1, 2011, 2:24 AM
Post #5 of 12 (1904 views)
I know how to use an esr meter but don't have and don't want to buy one for this one repair I have a schematic I made a living for over 30 years repairing tv's but went on to other work however the company I worked for sold and repaired only Zenith the cap meter will do for this job,thanks
Apr 1, 2011, 3:22 AM
Post #6 of 12 (1900 views)
need help1;....
Another old fart who apparently quit the biz.....Wink....Welcome....Sly...
Maybe , maybe not....We'll see...
I have a schematic ..
I asked if you had a "service manual"....Not a simple schematic...
You & I both know a schematic is NOT the same as a manual....
I'd REALLY appreciate a list of these;....
(This post was edited by Ron.M on Apr 2, 2011, 2:33 AM)
Apr 3, 2011, 5:52 PM
Post #7 of 12 (1873 views)
need help1;.....
I'm guessing you're pissed about something I said as you have not replied for 3 days....Unsure...
Did you figure out the problem ???
Get help from another forum ????
Nothing I said is chiseled in stone , so what happened ???
A reply WILL be appreciated...Smile...
Have a GREAT day.....Sly....
need help 1
Apr 3, 2011, 6:21 PM
Post #8 of 12 (1868 views)
Taking the weekend off will be back monday. thanks
Apr 3, 2011, 9:06 PM
Post #9 of 12 (1863 views)
Did I "miss" a Holiday (long weekend)?
Apr 3, 2011, 9:46 PM
Post #10 of 12 (1857 views)
Re: [jts1957] ctc 169 [In reply to] Can't Post
jts1957;.......
Yes , you did....
Ever hear of April the oneth ???...
It's April Fools weekend....Sly....Yeah , right...
need help1;....
When you are ready , here's what I'd suggest/appreciate you do....
Use care removing the HOT (Q4401) as there may be a residual charge there...
After you remove the HOT , with the set unplugged , hook up your meter to the collector connection on the chassis...
Plug the set in & read the B+ volts....
Then turn the set on & read the volts again....
Leave it on & see if it turns off & then back on as it was doing initially....
Observe what the B+ is doing...
Post readings & what the set & B+ does....
THANKS....Sly......
(This post was edited by Ron.M on Apr 7, 2011, 2:45 AM)
need help1
Apr 8, 2011, 1:42 PM
Post #11 of 12 (1815 views)
against my advise the owner of the tv decided she wanted a new flat screen. Thanks for all the help.
Apr 8, 2011, 4:22 PM
Post #12 of 12 (1811 views)
need help1;...
In a couple of years or less just when the warranty runs out , she'll be sorry....
They look pretty now , but............
Have a GREAT day & weekend....
Later...Ron.M....Cool.....
