Larry E
Aug 28, 2006, 7:09 PM
Post #5 of 6
(1800 views)
Stan, I don`t have the service manual for that set so I can`t be of much help, your either using the wrong ground or your measuring the wrong pin on your relay, sounds like your measuring the AC side of the relay on a DC setting of your meter, the relay is not your issue at this point, the lack of B+ to the HV circuit is.Remove the horiz. output transistor from the circuit and measure your B+ voltage at the collector trace again, positive probe of your meter to trace marked "c", negative probe to trace marked "e". If you don`t get approx. 135 volts your switch mode power supply has failed, let us know, Larry E
