dead set
old timer
Apr 18, 2006, 2:31 AM
Post #1 of 4 (2215 views)
dead set Can't Post
Howdy all! I have a Zenith A27A11D that I picked up on the side of the street. It has a main fuse blown-FX3401, and a thermistor (?) RX3415 that fell off of it's leads. I am not familiar with these newer sets, so if anyone can help me, I would surely appreciate it.
blkwolfpac
Apr 18, 2006, 4:31 AM
Post #2 of 4 (2208 views)
Re: [old timer] dead set [In reply to] Can't Post
replaced blown fuse and resolder thermistor back in placed. you might want to ohm thermistor out before you solder it back in place. See if there is another thermistor on the board and ohm that one too they should be closed in values...then go fromthere ....good luck
Apr 18, 2006, 9:25 PM
Post #3 of 4 (2200 views)
The blown fuse is usually a sign the the voltage regulator (probably an STR53041) is shorted which is a common occurance in older Zeniths.
old timer
Apr 18, 2006, 10:37 PM
Post #4 of 4 (2197 views)
Re: [blkwolfpac] dead set [In reply to] Can't Post
Thanks for the reply. I will defintely take this under advisement.
