flashing backlight
luckyc77
Jun 14, 2015, 12:24 AM
Post #1 of 9 (1587 views)
flashing backlight Can't Post
vizio e420-a0 I purchased a new power board and main board from shop jimmy installed both now i get flashing backlights. what am i missing that could be causing this any help would be great thanks
Jun 14, 2015, 3:07 AM
Post #2 of 9 (1581 views)
Re: [luckyc77] flashing backlight [In reply to] Can't Post
Capitalization P-u-n-c-t-u-a-t-i-o-n TV's Original history/symptom(s)
luckyc77
Jun 15, 2015, 11:11 PM
Post #3 of 9 (1558 views)
Re: [jts1957] flashing backlight [In reply to] Can't Post
Model# E420-A0
Part#10235492022
SN# LAUKNREN4802421
Tv had no sound no image given to me from my grandmother.
I took the whole thing apart disconnected screen and had only main and power board in so i could see the backlights, when i power on the backlights come on but flicker faintly.I have replaced both boards, tried them with out the remote sensor and with out the manual power buttons on still have same problem thanks in advance
Jun 15, 2015, 11:55 PM
Post #4 of 9 (1555 views)
Model# E420-A0
Part#10235492022
SN# LAUKNREN4802421
IF you do NOT have the remote sensor or manual power buttons connected, how do you turn it on/off?
http://www.shopjimmy.com/...0-strips-1-board.htm
luckyc77
Jun 16, 2015, 1:39 AM
Post #5 of 9 (1552 views)
disconnected remote sensor first tried with manual buttons same result
then disconnected manual buttons and tried with remote to see if i had short in one of them same result
Jun 16, 2015, 2:03 AM
Post #6 of 9 (1551 views)
And the LEDs?
luckyc77
Jun 16, 2015, 2:06 AM
Post #7 of 9 (1549 views)
the do the same thing no difference between which one is plugged in
luckyc77
Jun 16, 2015, 2:13 AM
Post #8 of 9 (1548 views)
I also do not own a multi meter that is why i just bought both boards
I bought them at different times and power board first didnt see any lights
then bought main board and didnt see any lights that is what made me decide to take it all a part
that is when i observed the lights flashing.
is there a chance i just got a bad power board?
Jun 16, 2015, 2:47 AM
Post #9 of 9 (1543 views)
Assuming no actions observed with BOTH the original boards installed ...
ANY sound or image when flickers? OSD? You DO have an active input selected and connected?
1) With the replacement Main board installed: If still flickers with either power supply installed - both are good ....
http://www.ebay.com/...-7R1-B-/271764256587
http://www.datasheetbay.com/...99/LC420DUG-JFR1.pdf
2) IF no action at all with the first PS reinstalled ... 1st supply bad in one way & 2nd supply bad in another way ... try a third
