gateway plasma tv
coyotehunter
Jan 17, 2018, 12:28 AM
Post #1 of 10 (1000 views)
gateway plasma tv Can't Post
i have a Gateway plasma tv manufactured in 2003----I just cut the cord from Directv---- new antenna input when connected does not produce local channels or any tv---- antenna works on other tv,, but TV mode on Gateway doesn't work---Amazon fire works on this TV, but I diconnected it while trying ti establish air input
Jan 17, 2018, 1:48 AM
Post #2 of 10 (994 views)
Re: [coyotehunter] gateway plasma tv [In reply to] Can't Post
To little information.Unimpressed
coyotehunter
Jan 17, 2018, 3:16 AM
Post #3 of 10 (984 views)
Re: [jts1957] gateway plasma tv [In reply to] Can't Post
i'm trying------what more info needed-----TV worked fine with cable going to same connection
Jan 17, 2018, 3:48 AM
Post #4 of 10 (979 views)
Let's start with: "gateway plasma tv"
All of them.
None of them.
One of them.
See the problem?
coyotehunter
Jan 17, 2018, 5:05 AM
Post #5 of 10 (974 views)
well,,,,, it's one of the first flatscreened plasma TVs(2003), and the brand is Gateway
Jan 17, 2018, 5:42 AM
Post #6 of 10 (968 views)
Is SOURCE on Cable or Air?
I usually want a mention of the model number, but in this case there may only be a few to choose from.
coyotehunter
Jan 17, 2018, 5:50 AM
Post #7 of 10 (965 views)
air
Jan 17, 2018, 7:23 AM
Post #8 of 10 (964 views)
Analog TV Tuner - NTSC
https://en.wikipedia.org/...elevision_transition
After the switch from analog to digital broadcasts is complete, analog TVs will be incapable of receiving over-the-air broadcasts without the addition of a set-top converter box. Consequently, a digital converter box – an electronic device that connects to an analog television – must be used in order to allow the television to receive digital broadcasts.
coyotehunter
Jan 17, 2018, 6:40 PM
Post #9 of 10 (952 views)
hey!!! thank you much!!! you are making EXPERT sense!!!
if you ever want to go coyote hunting,, I am an expert on that...
the thing is,, why didn't you tell me all this 2 weeks agoWink
Jan 17, 2018, 9:24 PM
Post #10 of 10 (948 views)
1) The Holidaze
2) Too distracted watching Roadrunner toonz. Beep-Beep.
