Jun 21, 2007, 2:08 AM
Post #5 of 14
(2481 views)
Re: [ernie] grundig guvcd2800(ak49)dead
What you are describing is a fix for a cathode heater short, if that is your issue it just means that the heater floats at the same potential as the cathode so there is no short. It will last as long as the tube will last, I have an abandoned Sony working in a relations house for 6 years now which has never failed. 2 points I will make is the wire is wrapped around the ferrite former of the transformer and locked there as far away from the overwind as you can, the wire should be well insulated, I use focus lead for it, 2 winds is OK, I have stepped this up on a flat tube to 3 winds as a last resort, that though will age the tube faster.
