horizonal problem
ladylovetv
Sep 26, 2007, 5:10 PM
Post #1 of 5 (959 views)
horizonal problem Can't Post
I have a hitachi 36" tv ,If I move my tv for any reason or if a fuse goes out in my house it makes the whole screen go horizonal,If I unplug everything from it and let it set a few days then sometimes that fixes it.FrownAny advice
Sep 26, 2007, 5:20 PM
Post #2 of 5 (955 views)
Re: [ladylovetv] horizonal problem [In reply to] Can't Post
do you mean the picture collapses into a horizontal line? if so then the vertical scan ic probably needs resoldering as there is a bad solder joint on one or more pins.
ladylovetv
Sep 26, 2007, 5:28 PM
Post #3 of 5 (954 views)
Re: [techchris] horizonal problem [In reply to] Can't Post
The whole picture is horizonal.Just by moving it will mess it up.
Sep 26, 2007, 7:11 PM
Post #4 of 5 (949 views)
you have a loose connection or bad solder joint somewhere.if you are able then use an insulated plastic stick to prod around inside till you find the area of the tv where the problem is.should not be too difficult
ladylovetv
Sep 27, 2007, 2:04 PM
Post #5 of 5 (938 views)
thanks,I will try that.Shocked
