Jul 29, 2005, 11:20 PM
(2325 views)
Re: [bizzle_bizzle] jvc model AV-27BP4
For $20 you can download the service manual at www.samswebsite.com. If what you really mean is the you ONLY have a "horizontal line" on your screen and would like to have a full screen display, you have a vertical sweep problem and it is probably a bad solder joint on the vertical IC or the IC has failed. I believe that in that model, the IC is identified as IC421.
