capted
Jan 18, 2008, 8:02 PM
Post #6 of 7
(1960 views)
Re: [mikemaiertv] panasonic 47x54 problems
I started checking the powers at each chip So far all is good!!! I checked the stk powers and they are all good.. This is why I'm losing my mind!!! I did not get them all done yet though. Hopefully I will find that (I can't believe I missed that!!!)one. As far as an eeprom goes, it seems to store the info and any changes I make with no problems. The convergence lines do move when I adjust them also, just not far enough. Not a setting or service menu problem for sure. The only piece of the puzzle is this other add-on convergence board. There are a bunch of big chips on it. No info on this board except to just replace it if it is bad(DUH!!). I am wondering if this board controls the auto convergence on the set?? It's bugging me that so far every power test is good and there are no physically bad components. This set is only 3 years old. My mitsu is 6years old and only had to resolder the stk's...(oops, maybe I shouldn't push my luck)... Again thank you for your help. I really appreciate it. Any other ideas??? I will check ALL of the chips powers and power supplies just to be sure. There must be something in common with the convergence and audio.. And the schematics I have are missing one page of the d-board. Guess which one---the one with the second convergence amp.. Go figure. Just using a scematic from a bigger model 53x54 for the missing page.. I hope it is correct.
