Mar 11, 2016, 6:01 PM
Post #3 of 3
(1244 views)
Re: [kingfish49] panasonic TS32 lx60
kingfish49;... I do not work on LED/LCD or Plasma TVs... But , I've picked up tidbits of knowledge by watching & learning from the pros here , including jts1957... ... That said , try this... There's a possibility that the pushbutton panel is acting up... That's the panel that has power on , vol up & down , chan up & down etc pushbuttons on it... Try turning the TV on then QUICKLY unplugging that small panel & see if the nonsense stops.. IF it does , you can either repair that panel or get a new one.. Be CAREFUL how you unplug that connector so you DON'T damage the connector OR the wiring that goes to it... If it does not stop the nonsense , you may have a bad Main Board.. That panel usually is nonrepairable & should be replaced with an EXACT replacement.. Good Luck... ... Later..Ron.M.... ... Veteran & Retired TV technician
