May 20, 2012, 6:35 PM
Post #3 of 3
(1281 views)
jts1957;..... Thanks for that manual.... dstafisreal;..... On page 6 you will see a "special" remote (RC2573GR Setup Remote) you will need to switch from commercial to consumer use.... You will also see a remote you will need to use the set.... On page 8 is the proceedure you should follow with the "special" remote as shown below;=>.... The television is shipped in Commercial mode; however, at times it may be necessary to operate the set in Consumer mode. To switch between Commercial Mode and Consumer Mode the following sequence should be followed: • With the RC2573GR Master setup remote enter 024995 and press the menu key. • Use the Right cursor button to switch the Mode of the set between Consumer and Commercial. • With the proper mode selected, cursor down and use the Right cursor button to store the selected mode. • After the mode is stored, the television will power itself off. At this point disconnect You're going to need the RC2888/01 Guest Remote OR similiar remote to use the set... My suggestion would be to take the TV to an "AUTHORIZED Philips/Magnavox" Service shop & let them convert it over for you.... It should take them 5~10 minutes & $10~20 USD to do the job... Since it's a one-time deal , why buy a "special"(Green) remote you are going to use one time , then it sits in a drawer somewhere... Good Luck.... .... Later...Ron.M.... .... Veteran & Retired TV technician
