Aug 13, 2006, 11:49 AM
Post #3 of 10
(1150 views)
Re: [ernie] philips widescreen tubes
What actually is the issue with the tube, if it is going cathode heater short as per Sony, the cure is to isolate the heater. If the heater is earthed one end this is usual, cut print isolate both pins and wind 2 winds of wire around the arm of the flyback transformer as far away as you can from the main body of the tranformer, hook up to the isolated pins, check for 6,3V at hor. freq and its fixed. And Yes Chinese are buying tubes by the ship load and reinventing them into cheap new TVs here. It is technically illegal but no one seemsto want to know
