phillips 27
applegate
Feb 15, 2007, 4:30 PM
Post #1 of 4 (1484 views)
phillips 27 Can't Post
Hello all out there. I have a power problem with a phillips model PA5027 C203, or chasis model 27V514-00AA. When you turn it on either by remote or front panel the green power led comes on for a few seconds and then shuts off. You never actually see anything on the screen. Thanks in advance for your time and help.
Feb 15, 2007, 11:16 PM
Post #2 of 4 (1472 views)
Re: [applegate] phillips 27 [In reply to] Can't Post
I believe that is the model with a high failure rate of the vertical output IC which in turn takes out the IC +/- B+ power supply diodes and their fusible resistors resulting in these symptoms.
applegate
Feb 16, 2007, 5:01 PM
Post #3 of 4 (1458 views)
Re: [mel] phillips 27 [In reply to] Can't Post
Is there an easy fix? Can I change out an IC and a few diodes and be back in business? Thanks for your response.
Feb 16, 2007, 11:24 PM
Post #4 of 4 (1454 views)
If that is really the problem, it is a matter of changing the IC, two diodes and two resistors. If you have any soldering skill, it should be an easy job.
