BenJF3
May 2, 2009, 5:54 PM
Post #6 of 6
(1167 views)
Re: [Repair man] picture is 'jumping'
Yes, it could be in the vertical circuit as well. As a rule of thumb, whenever I do a repair I always inspect the chassis for poor/cold solder joints. I had a number of Hitachi Projection sets that burned the tubes because the customer let the problem go. You can still use the set after the tubes burn, but you will always have spots in the picture, so as Repair Man said "get to soldering".
