darstr
Oct 18, 2010, 4:25 PM
Post #3 of 3
(1009 views)
Re: [russell1957] plasma tv fault
Put a piece of tape on the bezel where the black bar is, that way you know where it is at when you take the back off. Where that tape is, there will be a flat ribbon connector on the bottom of the set. Pull the cable out and clean it. Make sure you get it back in perfect and tight. If that does not fix, it could be your board it is attached to, or the panel. Good luck to you.
