Jul 6, 2015, 12:47 AM
Post #2 of 4
(1221 views)
Re: [mountaindew11] power board fuse
Same Vizio, I assume? IF the set has ANY sign of life, it's NOT 'that' fuse.Measure across the fuse with an DVM set on ohms or continuity. a good fuse will read very near zero or beep continuously.Fuse is held in with solder on the back side of the board. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Jul 6, 2015, 12:50 AM)
