kylum
Jul 23, 2007, 9:20 PM
Post #3 of 5
(1112 views)
Re: [Paulpablo] rca f27318 Help!!!
L4401 was the problem. The pin coming through the board wasnt through all the way and wasn't even solderd. I wasn't sure which spot to solder though there was two different spots next to each other i went for the smaller whole because the other pin went through a the same size hole. Plus both holes were connected to the same trace and nothing in between them. Now the screen comes on and stays on. thanks Paulpablo. But now the screen has small lines in it and they are jumpy. There is a sound coming from the back of the picture tube, where the high voltage plugs into the tube. The sound goes away if i adjust the screen but the screen gets to dark and you cant see shit. If u turn the screen up the sound get worse and so do the lines. what causes this. Is it the connection at the tube, bad connection, or dust??? Help please. Thanz in advance
