rear projection question
xmechman93x
Mar 8, 2010, 3:01 AM
Post #1 of 3 (830 views)
rear projection question Can't Post
Ive recently picked up a Magnavox FP4630 W104 rear projection set. It had pore picture quality so i cleaned the mirror and lenses with alcohol lens wipes of the dust and the screen dusted off. The picture quality is far better than before although not as good as i think it can be.
Ive played with the picture settings but the colors seem to not be as true or bright as i think they should be. There is also a ''halo'' effect or bleed off from bright colors (namely white).
Is there any other adjustments i could do to the set for better picture? Thanks.
Mar 8, 2010, 3:07 AM
Post #2 of 3 (827 views)
Re: [xmechman93x] rear projection question [In reply to] Can't Post
Search for one of Ron's Coolant change threads.Wink
Mar 8, 2010, 8:58 PM
Post #3 of 3 (809 views)
xmechman93x;.....
I've been here awhile & I can't find one of my coolant threads...Unsure....
Check out this link....
http://www.riddledtv.com/...RTCoolant/index.html
It's NOT for your TV but shows how to do it....
On the 1st page is where you can see if coolant is your problem or not...
IF is not , can you post a pix of your problem so we can see what you're talking about ???
My method is a bit different....So if you need to do it , I'm willing to help...
Jts1957;....
Can you show me how to do this;=>...
""Search for one of Ron's Coolant change threads."""
Thankx....Sly....
Later....Ron.M.....Cool....
