samsung needs help
teapot
Aug 20, 2013, 6:12 PM
Post #1 of 8 (1471 views)
samsung needs help Can't Post
i have a samsung 32in model number le32b530ptw
for a few days when i switch on i get sound and picture
after a few minutes screen turns black no picture but
still sound.
last night turned on worked all night.
today sound no picture not at all
i removed the back and can see the inverter transformer
has burn mark
i would like to know if it is safe for me to remove
this part myself is there a charge in it
they sell them cheap on ebay
i have asked shops to fix but cost a lot
leonard085
Aug 28, 2013, 8:59 PM
Post #2 of 8 (1422 views)
Re: [teapot] samsung needs help [In reply to] Can't Post
 changing this component is easy if you have basic soldering skills,
but I would not rule out further problems with the lamps,
here is a link for the 40" version https://www.youtube.com/watch?v=wrD1d-a2fnA
this shows work on the power supply
Aug 29, 2013, 8:06 PM
Post #3 of 8 (1389 views)
Re: [leonard085] samsung needs help [In reply to] Can't Post
leonard085;....
Well , you did it again....
I wasted 9 mins & 18 secs on a video that has NO bearing on "teapot's" problem !!!!!...NONE !!!
The video is NOT clear , out of focus...
The audio is impossible to understand what the guy is saying , even the closed captions are screwed up...
It does NOT give ANY help on how to solder....
It does NOT give ANY help on how to fix his TV !!!!!
TOTALLY IRRELEVANT !!!
Wasted time & effort...
Once again you TOTALLY missed the mark...
I will agree with you on this ONLY:=>>...
"" changing this component is easy if you have basic soldering skills,"""
Other than that , you screwed up again...
teapot;...
Transformers do NOT hold a charge...
Capacitors can & do...
As for your replacing the part yourself;....
How much electronic/TV repair background experience do you have ????
Do you have any soldering experience ???
If you need help soldering , I can provide you with some videos to help you learn...
Start here;=>...
http://www.google.com/...7.2.1750.js7B4Td9SI8
IMHO , I'd guess that that burn mark indicates a bad transformer & since you said they are cheap , what have you to lose but a small amount of cash & some time....
Go for it...Wink...
GOOD LUCK....Smile..Smile...Smile...
Later...Ron.M....Cool...
leonard085
Aug 29, 2013, 10:03 PM
Post #4 of 8 (1381 views)
Re: [Ron.M] samsung needs help [In reply to] Can't Post
Ron,
you are an asshole
as for wasting time, you are wasting my time in replying to your comments
its lucky you are retired,
because you have not got a clue about modern electronics,
Aug 29, 2013, 10:33 PM
Post #5 of 8 (1380 views)
No results found for "How to solder TV components".
Aug 29, 2013, 11:53 PM
Post #6 of 8 (1371 views)
leonard085;....
Be advised that there is a ZERO tolerance here for swearing (Cuss words to you)...
You continue to swear & I'll recommend you be permanently banned from this forum...
I currently enjoy a 100 % success rate in that catagory...
I prefer to be called SOB Ron....
Better said as Swell Ole Buddy Ron....Smile...Smile....Smile...
At least I know that a 12 volt zener can NOT regulate at 5 VOLTS !!!! ...
I also probably forgot MORE than you'll ever learn about electronics...
IF you had NOT posted an irrelevant poor quality video , I would NOT have commented !!!!..
Had you posted a video that WAS relevant to teapot's problem , I would have NOT commented !!!...
So much for YOU wasting YOUR time ...
What about the others here that may also have wasted their time watching that video ???...
jts1957;....
My link works !!!!..
Here it is again;=>...
For some strange reason , yours does not;=>...
IF you scroll ALL the way down on my link you'll find this;=>...
""How To Solder Components
  • www.info.com/HowToSolderComponents
    Get How To Solder Components Info Access 10 Search Engines At Once.""
    jts , have a GREAT day & weekend.....Sly...
  • Veteran & Retired TV technician
    (This post was edited by Ron.M on Aug 30, 2013, 12:16 AM)
    Aug 30, 2013, 2:39 AM
    Post #7 of 8 (1360 views)
    "I know nothing," about why my copy of your copy of link doesn't work.
    I did refer to the fact that the query you posed (as posted) produced no results.Tongue
    Ads related to "How to solder TV components"
    Aug 30, 2013, 4:39 PM
    Post #8 of 8 (1345 views)
    Re: [jts1957] samsung needs help [In reply to] Can't Post
    jts1957;...
    HUUUHHHhhh !!!
    I can't find that in any of my posts !!!
    Only on "Google"...
    & , yes , it was an ad , which isn't there today...
    IF you clicked on it you'd get sites that would help...
    I can't do everything for OPs...
    If teapot needs further help , I'm sure he'd post...
    The link I gave was & is a starting point...
    Certainly MORE helpful than that ridiculous video !!!!...
    Have a GREAT weekend....Sly...
