samsung repair
bombidragon
Jul 17, 2010, 12:08 AM
Post #1 of 22 (2537 views)
samsung repair Can't Post
I have a 26" Samsung tube tv that i removed the case off of to use as a arcade monitor.. Took the case off and got it mounted and there is no picture. Turns on makes all the fun degaussing and crackling noises. The normal buzz noise changes when I switch channels just no picture. It has a separate board for the ir and the power button that got broke in half in the process but i do not need the ir and i figured out what pins are power.
Any basic stuff i can check?
thanks
Jul 17, 2010, 12:31 AM
Post #2 of 22 (2536 views)
Re: [bombidragon] samsung repair [In reply to] Can't Post
Arcade monitors usually don't need/use tuner. R/G/B/H&V Sync; some even use SVGA plugs.
Of course you could connect cable to it and watch HBO.Cool
bombidragon
Jul 17, 2010, 12:43 AM
Post #3 of 22 (2532 views)
Re: [jts1957] samsung repair [In reply to] Can't Post
i think you misunderstood. I am using a tv as a arcade monitor that will hook to a pc via s-video. I got it all handled except for the fact i have no video after i took the case off and mounted it. Its gotta be something easy. I do get a little about 20v ac shock from the grounds which is a little weird but i have little experience with tvs.
Jul 17, 2010, 2:36 AM
Post #4 of 22 (2531 views)
You are attempting to put it on a external input (A/V1, Line In)? Usually NOT channel up/channel down. "VIDEO" button on remote perhaps?
This implies you DID have video BEFORE taking the case off and mounting it.Unsure
20VAC - could be worse. Try holding a cold water pipe and a ground at the same time with opposite hands.
bombidragon
Jul 18, 2010, 5:12 AM
Post #5 of 22 (2519 views)
i got that part handled with the switching of channels. i just need basic tips on what to check to start out with. like check voltage between points ab that kind of stuff.
thanks
becyn
Jul 18, 2010, 4:28 PM
Post #6 of 22 (2514 views)
Ok, I'll state the obvous questions:
1) did set the tv to the proper input?
2) define "no video" no hv no sound no anything or just no video?
3) do you see a menu if you press the menu button?
I was "shocked" to read some of the other stuff, but I will refrain from commenting. I hope you read the site dislaimers.
Visit McVey Electronics for TV Repair!
bombidragon
Jul 18, 2010, 7:03 PM
Post #7 of 22 (2510 views)
Re: [becyn] samsung repair [In reply to] Can't Post
no light output from the tube.
becyn
Jul 18, 2010, 7:11 PM
Post #8 of 22 (2509 views)
*sigh*
Too vague
How about going through the questions above, answering them in a clear and succinct way.
"no light from the tube doesn't tell me if you get a menu, sound,or what mode the set is in".
bombidragon
Jul 18, 2010, 7:21 PM
Post #9 of 22 (2508 views)
really, this is amazing. No menu nothing the tube is not lit up , no photons are coming out of the screen.
I do get the highfrequency buzzing sound from the electronics and you can hear it change when you switch channels and inputs. It degausses like normal.
thanks
(This post was edited by bombidragon on Jul 18, 2010, 7:24 PM)
becyn
Jul 18, 2010, 7:36 PM
Post #10 of 22 (2502 views)
Ok so everything works EXCEPT getting a pix?
Off the top of my head:
1) some older sets had "service mode" switches that when set in a position would intentionally kill the video. These were usually a plastic toggle switch located on the CRT "neck board". You may have hit that.
2) video mute due to vertical deflection failure.
bombidragon
Jul 18, 2010, 7:54 PM
Post #11 of 22 (2501 views)
no switch checking the website out now. I would figure it would have been a plug or wire but i cant find any extras
bombidragon
Jul 18, 2010, 7:56 PM
Post #12 of 22 (2500 views)
not really any info on site unless i want to send it in. :(
bombidragon
Jul 18, 2010, 8:40 PM
Post #13 of 22 (2495 views)
got a website with alot of info, The crt filament is not glowing and i have horizontal deflection. The rest i dont know about. How do i test the circuit for the crt filament
Jul 18, 2010, 10:00 PM
Post #14 of 22 (2489 views)
Shall we try pulling teeth... I mean extracting a model number?
bombidragon
Jul 18, 2010, 10:11 PM
Post #15 of 22 (2485 views)
i dont have the outside case anymore i hucked it 2 weeks ago. it is a Mitsubishi tube.
it would be easy to figure it out with pics because it has the power button at the top
(This post was edited by bombidragon on Jul 18, 2010, 10:14 PM)
Jul 18, 2010, 10:20 PM
Post #16 of 22 (2481 views)
Hold a neon lamp against main body of flyback - does it light?
bombidragon
Jul 18, 2010, 11:13 PM
Post #17 of 22 (2478 views)
yes it does so that has power
Florescent light correct?
(This post was edited by bombidragon on Jul 18, 2010, 11:14 PM)
Jul 18, 2010, 11:38 PM
Post #18 of 22 (2474 views)
NEON - hold glass bulb against - NOT leads.
bombidragon
Jul 19, 2010, 12:03 AM
Post #19 of 22 (2470 views)
dont have one on me and it lit up a whole 36 inch florescent tube by putting it next to it. same effect i would think.
Jul 19, 2010, 12:41 AM
Post #20 of 22 (2466 views)
Confirms you have high voltage.
Without model number - can't search for service literature to find out how CRT filament is supplied with power.
becyn
Jul 19, 2010, 12:46 AM
Post #21 of 22 (2464 views)
Dude! You don't make it easy.
No model number, vague info, etc.
Well, my friend, it's like this:
If there is no crt filament light (and you checked this in the dark), then that is a bad thing.
On the neck board check for filament continuity. ( labelled H) If that's Ok, then there is an open circuit between the filiment connections and the flyback.
This could take the form of loose wire, cracked board, open solder or open fuseable resistor link.
Since you have chucked the model data, that's all anybody can tell you.
Good luck...
bombidragon
Jul 19, 2010, 12:55 AM
Post #22 of 22 (2463 views)
thanks for all of the help
