samsung tv
johnj
Nov 4, 2011, 1:41 AM
Post #1 of 20 (2753 views)
samsung tv Can't Post
i have a samsung ln40a650 tv when i turn it on when its cold i have a dark left side and a line on that side to but after it warms up the picture is great any one have a idea what is the problem???i hope its not the panel...Pirate
thanks,john
Nov 4, 2011, 3:17 AM
Post #2 of 20 (2745 views)
Re: [johnj] samsung tv [In reply to] Can't Post
See if line moves to a different spot when you change the aspect ratio. If it stays in same spot = panel =
johnj
Nov 4, 2011, 3:37 AM
Post #3 of 20 (2742 views)
Re: [jts1957] samsung tv [In reply to] Can't Post
yes it moves and like i said in about 10 minutes it gooes away completly and the picture is fine only for the first 10 minutes do i have a problem after that it works fine..
johnj
Nov 6, 2011, 7:29 PM
Post #4 of 20 (2731 views)
nobody have a idea what it is i took the back off checked the capacitors they all look good...
thanks,john
Nov 7, 2011, 7:25 AM
Post #5 of 20 (2725 views)
So when set is cold you CAN change the aspect ration (as many times as you desire) and the line moves to a different location - UNTIL THE SET WARMS UP?
I'm having trouble envisioning ANY part (Resistor, capacitor, diodes, transistors or ICs) where "Looks good" is the definitive test to check them. Even a glass fuse can "Look Good" yet be bad or vica versa.Crazy
Although every one of the parts listed above CAN fail in ways that are obvious just looking at them.
johnj
Nov 7, 2011, 6:15 PM
Post #6 of 20 (2720 views)
i know looking good does not mean a lot but like i said before there are two little lines but thats not the problem the picture is washed out i mean it is real dark and smeared to and after about 3 minutes its like when you first turn a good tv on the picture comes on great after 3 minutes of warm up ...
Nov 7, 2011, 6:54 PM
Post #7 of 20 (2718 views)
Am I reading the word according to johnj incorrectly?
Now there are two lines. Problem getting worse?
(This post was edited by jts1957 on Nov 7, 2011, 6:58 PM)
74f100
Nov 8, 2011, 1:46 PM
Post #8 of 20 (2701 views)
Sounds like a typical panel delamination. If you press on the upper left side when the problem is visible, it should go away. There hasn't been a sure fire fix for it yet. But a few are working on it (me included).
Jim
HDMI not working
johnj
Nov 8, 2011, 6:39 PM
Post #9 of 20 (2694 views)
Re: [74f100] samsung tv [In reply to] Can't Post
thanks but if i had a panel problem wouldn't it be there after it warms up to. like i said in the first listing it works fine after a 3 minute warm up... thanks,john
74f100
Nov 8, 2011, 11:34 PM
Post #10 of 20 (2688 views)
Yes John that's how that happens.
HDMI not working
johnj
Nov 8, 2011, 11:39 PM
Post #11 of 20 (2687 views)
Piratethanks for your reply i guess i'll just live with it till goes completely out...
74f100
Nov 8, 2011, 11:45 PM
Post #12 of 20 (2685 views)
Can you get a picture of it? This can confirm the problem.
HDMI not working
johnj
Nov 8, 2011, 11:57 PM
Post #13 of 20 (2684 views)
yes i'll try to get a picture but like i said it only takes about 2-3 minutes and then the picture is good all day it seams like the colder the tv is the longer it takes to come on with a great picture.. thanks,john
johnj
Nov 9, 2011, 12:03 AM
Post #14 of 20 (2682 views)
the picture is fine know i had it on a little bit ago so it has to be real cooled off before it does it once you turn it on it takes all most all day before it does it...
74f100
Post #15 of 20 (2682 views)
It comes from the sync lines lifting slightly. If you take the panel apart, you just touch the ribbon cable and the problem goes away.
Once it heats up, it gets a good connection. I've fixed a few by heating and re-gluing the cable to the panel.
HDMI not working
johnj
Nov 9, 2011, 12:08 AM
Post #16 of 20 (2679 views)
do you think i should just leave it alone because like i said it only has a problem for a couple minutes on start up
(This post was edited by johnj on Nov 9, 2011, 12:10 AM)
74f100
Nov 9, 2011, 12:18 AM
Post #17 of 20 (2672 views)
For now, yes leave it alone. I am still working on perfecting a technique that will work and hold up.. Messing with it can make it worse.
HDMI not working
johnj
Nov 9, 2011, 12:23 AM
Post #18 of 20 (2671 views)
thanks 74f100 for your time i'll just watch it and see if it gets worse.
thanks again,john lodi,ca
johnj
Nov 9, 2011, 2:27 AM
Post #19 of 20 (2660 views)
74f100 i just looked at your web sit WOW IT WAS GREAT TO SEE ...
THANKS AGAIN,JOHN
johnj
Nov 9, 2011, 11:34 PM
Post #20 of 20 (2645 views)
74f100,Sly was right on it was the sync lines lifting slightly from the panel..
