sanyo closed caption
dumpster
Nov 5, 2009, 8:58 PM
Post #1 of 3 (10036 views)
sanyo closed caption Can't Post
sanyo 20 inch standard tv; model DS19310. closed caption won't turn off. i don't have origanal remote and that is where the cc button is located. the internal menu has nothing to turn it off with like most tv's have. looked at pdf manual for tv say's cc can also be turned off by pressing the mute button. tryed this with the all for one univeral remote but it didn't work. ihave some other universal remotes. any idea's would be appreciated.
Nov 6, 2009, 4:36 AM
Post #2 of 3 (10025 views)
Re: [dumpster] sanyo closed caption [In reply to] Can't Post
Sounds like you need the ORIGINAL remote and that you're confused about Quikcap. Do a search for the EXACT replacement remote!
Quikcap: Quikcap allows captions to toggle on and off with the Mute function. For
example, the phone rings; you press the MUTE key on the remote control to block the TV
sound; the captions display automatically. When you finish your conversation and press the
MUTE key again to restore the sound, the captions will disappear.
Quikcap displays program captions in the Caption1 mode.
SETTING CAPTIONS
1. Press the CAPTION key on the remote control.
2. Use the 0 key to select OFF, Caption1, Caption2, Text1,
Text2, or Quikcap.
To remove this black
box, set captioning to
any mode other than
Text1 or Text2 or press
the RESET key to
cancel captioning and
customized settings.
dumpster
Nov 6, 2009, 1:54 PM
Post #3 of 3 (10022 views)
Re: [jts1957] sanyo closed caption [In reply to] Can't Post
thanks for reply i'll be closing this post now.
