sony KV27FS16
glnkrg
Aug 22, 2006, 2:26 AM
Post #1 of 7 (1814 views)
sony KV27FS16 Can't Post
TV has a clicking noise when turned on and led flashes 4 times.no picture, no sound. "MEL", i need help please. <br>
(This post was edited by glnkrg on Aug 22, 2006, 2:32 AM)
kevin
Aug 22, 2006, 10:56 AM
Post #2 of 7 (1805 views)
Re: [glnkrg] sony KV27FS16 [In reply to] Can't Post
could be a bad vertical output ic, or perhaps power going to the ic
Aug 22, 2006, 9:19 PM
Post #3 of 7 (1793 views)
The 4 blinks indicates a shutdown caused by a vertical failure.
glnkrg
Aug 26, 2006, 6:38 PM
Post #4 of 7 (1769 views)
Re: [mel] sony KV27FS16 [In reply to] Can't Post
Would you happen to know off hand which vertical IC needs replacing ? IC601 or IC502 maybe ?
Aug 26, 2006, 8:03 PM
Post #5 of 7 (1766 views)
I do not have a schematic for that specific model but the vertiacl IC is usually IC561 and P/N TDA8172. Before you change the IC though check to make sure that you have +12 volts on pins 2 and 6 and -16 volts on pin 4. If any of these are missing, it would indicate a power supply failure. It could also be loss of vertiacl drive from the jungle IC but you will need an Oscope to determine this.
glnkrg
Sep 4, 2006, 2:46 PM
Post #6 of 7 (1724 views)
There is no 12v or -16v @the pins indicated. Anything to do with the relays? Where is the jungle IC ?
Sep 4, 2006, 9:13 PM
Post #7 of 7 (1716 views)
If you have no B+/- to the vertical IC, there is your problem. You can go to www.samswebsite.com and download the Photofact for that set and it will probably give you some detailed troubleshooting tips to resolve your problems.
