sony kv-32v36 dead
Girard Ibanez
Aug 29, 2004, 6:21 AM
Post #1 of 6 (3219 views)
sony kv-32v36 dead Can't Post
Any ideas as to how to trouble shoot a startup or shut down circuit for a sony kv-32v36. Tv is completely dead.
Aug 29, 2004, 10:46 PM
Post #2 of 6 (3208 views)
Re: [Girard Ibanez] sony kv-32v36 dead [In reply to] Can't Post
Start with a blown power fuse. Next a shorted diode in the bridge rectifier; or perhaps a bad voltage regulator; maybe an open power resistor or a shorted horizontal output transistor. It could be one or more of these items plus others not mentioned and it is difficult to determine without hands-on troubleshooting. Since you apparently have a completely dead set, the initial problem is more than likely in the primary power supply but ????????.
Girard Ibanez
Aug 31, 2004, 3:26 AM
Post #3 of 6 (3192 views)
Re: [mel] sony kv-32v36 dead [In reply to] Can't Post
There's got to be a logical way to troubleshoot this TV. Back in the days I used to use a isolation variable transformer and watch the signal at the HOT. This would indicate whether it was a start up or shut down problem.
Its been a long time now since I serviced a Sony and from past experience they are difficult.
Mel, the fuse is good in this set. No obvious indication or shorted diodes, transistors etc. in the power supply section. I haven't gotten around to the horiz transitor .... will post status.
In the mean time .... someone out there may have a common problem with this chassis.
Thanks
Girard Ibanez
Sep 1, 2004, 4:51 AM
Post #4 of 6 (3182 views)
Mel,
Do you have schematics for this Sony. Any other troubleshooting points for sony tvs
Sep 1, 2004, 11:34 PM
Post #5 of 6 (3177 views)
You can go to the SAMS website and download the Photofact for this set for $20. The Photofact will give you the schematic diagram and most of them include troubleshooting instructions. I believe that the Photofact number is 4777 but you should check it to make sure.
Girard Ibanez
Sep 3, 2004, 3:57 AM
Post #6 of 6 (3178 views)
Will do ....THANKS
