sony kv27v10
pluto12345
Aug 24, 2007, 4:30 AM
Post #1 of 6 (3374 views)
sony kv27v10 Can't Post
i have a sony tv model kv-27v10. <br>problem was it wont turn on.after testing i found q601,q602 shorted as well as q591.then the 607 fuse resistor was open. <br>q601 and q602=c4834 <br>q591=c4927. <br>i replace all this then tv turn on but after like 3minutes i so a thin black line on the right of the screen follow by a sound made by the fuse resistor which blow out. <br>then the same components went bad.what else could be causing this.thank you <br>
c4927 is the horizontal transistor and c4834 are switching regulators i think 7v regulators
(This post was edited by pluto12345 on Aug 24, 2007, 7:09 AM)
Aug 24, 2007, 6:16 AM
Post #2 of 6 (3366 views)
Re: [pluto12345] sony kv27v10 [In reply to] Can't Post
Try telling us what these transistors do, you are on the ww web so for two reasons you want to give better details. !/ I may not have that circuit. 2/ I have the circuit, but blow you why should I search my files to find it. So be more specific and you may be a happier chappie.
Hect7369
Aug 24, 2007, 4:08 PM
Post #3 of 6 (3354 views)
Everytime,you have to resolder all power/horiz circuit..
also,check and replace VDR's in power supply.
Franky
Aug 25, 2007, 12:22 AM
Post #4 of 6 (3345 views)
sony kv27v10 - NEW Quote | Reply
c4927 is the horizontal transistor and c4834 are switching regulators i think 7v regulators \
Also R644,T605,Vdr601,did you use q591,q601,q602,only by Sony#8-729-0 missing some #'s.
pluto12345
Aug 25, 2007, 5:27 AM
Post #5 of 6 (3334 views)
how do a check vdr601 with the volt meeter or do i just replace it.just by looking at it it looks fine.and t605 how do i check it.thank you
pluto12345
Aug 25, 2007, 5:55 AM
Post #6 of 6 (3334 views)
i set my meeter on ohms and check the t605 the side that is conected to r644 i get 5.1 ohms and the other side i get 00.4 ohms.i test it on the board an out the board
(This post was edited by pluto12345 on Aug 25, 2007, 7:04 AM)
