Larry E
Aug 6, 2005, 2:02 AM
(1307 views)
Re: [yas2pt0] sony screen replacement?
Hi, yes the average Joe can change them but you will need 2 people,be advised the screens are brittle and WON`t take a lot of abuse, I usually lay them on a sheet or blanket and tape them together at the 4 corners and at the center of both edges, don`t run the tape out into the center of the screen or it will show once installed, if your going to order the screens from Tritronics see if they have the PAPER service manual it will help with figuring out how to get everything apart and back together, remember don`t try to lay or stand up the screens by yourself get a second set of hands, good luck, Larry E
