Sep 12, 2009, 1:14 PM
(691 views)
Re: [kev2971] stk392-570 pin #3
ok i am replacing ic's and pin #3 on board the copper goes nowhere does this sound correct? external mute i believe it is a 55" mitsubishi 1080 series. any input would be great thanx in advance. You are correct. You have the item in front of you. Just because a IC has X number of pins doesn't mean manufacturers have to use them all. What does the other IC of the pair do with pin 3? ------------------------- Location: Far, Far Away
