BL_Thompson
TV Repair Authority
Feb 21, 2003, 9:17 PM
(2833 views)
I don't have access to the RCA files right now, nor will I until Monday. If you can provide the chassis number, I think I can help you... it will begin with "CTC" or "ATC". In the mean time, you might try "smacking" the set... slap it on the top or the side. If the vibration affects the problem, you have a bad solder connection. No need to be gentle, but don't use a hammer ^_^ ----------------------- Bryan Thompson Spyder Byte Services Albuquerque, NM
