Barry777
Jan 16, 2010, 10:29 PM
Post #10 of 12
(10203 views)
Re: [Dillon123450] SL-2401 Betamax Problem
Hi Dillon, I'm having a similar problem with a Sony SL-HF600. Most of these consumer Beta machines share fairly similar-looking mechanisms and probably also have fairly similar circuitry. I can fast forward and rewind just fine, but get no capstan or drum rotation at all when I go to Play mode. I get a click, and the pinch roller momentarily engages against the capstan until the machine finds out there's no drum or capstan activity, then it retracts the capstan and won't do anything else until I eject and reinsert the tape. I'm thinking more in terms of power supply problems, since I have two dead things at the same time. With no schematic or service manual, I did just a few quick voltmeter checks here and there. I get +5V, and plus and minus 15 volts at certain points on the PS board, but can't be sure other terminals are supposed to be energized by other circuits sending "turn on" signals to the power supply board. I'm not getting hardly any voltages on the system control board except a +5V at a few of the IC pins. This tells me that the computer stuff is being fed, but there are no drive voltages for the drum or capstan, as the chips controlling them aren't getting anything except computer power, and nothing to pass on to the drum and capstan motors. That whole board is basically dead except for that occasional +5 volts here and there. My next step will be to recap the power supply, as the electrolytics have reached the end of their expected life and I've already fixed a few machines by simply recapping the power supply. These problems were all servo lock related, and the capstan and drum drive circuits place the greatest demand on the wimpy switching-type power supply. Sure would like to have the service manual, it would make the troubleshooting much more efficient. Another possibility is a failed mode switch, which is probably buried deep in the mechanism - but would be another reason that more than one thing is dead, as it can make more circuits at once. Just in case you don't know, the mode switch is controlled entirely by physical movements in the mechanism. If it gets dirty or fails, it will still move when triggered by the mechanism, but of course won't make the required electrical connections. Another Beta machine I have loses servo lock about every 14 seconds, until the unit warms up and then it's fine. This is a sure sign of aging power supply caps. If you're like me (and it seems so), you want to get right into the complicated stuff, when the trouble is actually in a simpler area. But I would say recap the power supply as a first step - the machine surely needs it anyway, so you're not really wasting your time or money if that's not the trouble. From my experience, low cap/high volt units (such as 1 uF at 50 volts) are usually the ones most likely to be bad. I very seldom see a bad high cap/low volt unit, like 6800 uf at 35 or even 63 volts. Good luck! . . . . . Barry Fone - VCR Repair hobbyist and professional FAA Repair Station Avionics Bench Technician (top level). TEST EQUIPMENT: (4) Sencore VC93 VCR Analyzers, (11) Tentel gauges, Sencore VA48 and (2) VA62 Video Analyzers, Sigma Electronics TSG-375 NTSC/SMPTE Video Generator, several VCR Alignment Tapes, plus countless Oscilloscopes, Frequency Counters, Wow and Flutter Meters, Distortion Analyzers, Vectorscope, 136-channel Logic Analyzer, Signature Analyzer . . . . VIDEO GEAR: (6) JVC BR-S822U's, (3) JVC BR-7000 series, (3) JVC BR-S500U, (2) JVC BR-S800U, JVC GR-800U and (2) GR-860U Editing Controllers, Sony FXE-100 Video Switcher/Effects Generator, (5) Time Code Generator/Readers, (1) Sony SLO-1800 (Beta), (2) Alesis ADAT-XT, (1) Sony DXC-1200 TV Camera, Pioneer VP-1000 Laser Disc Player plus many consumer grade Beta and VHS VCR's. Passionate electronics enthusiast since 1973...most anything except computers. Check out my collection at www.barrys8trackrepair.com/MyVideoGear.html
