Barry777
Mar 13, 2010, 2:19 AM
Post #10 of 13
(3865 views)
Re: [Rob64] general vcr problem
If your VCR has not played a tape satisfactorily since you had the original problem, you should try cleaning the video heads or using a head cleaning tape. The description of the problem isn't quite detailed enough to make an accurate assessment, but one of your video heads might be dirty - especially if your picture has a pronounced flicker. "Horizontal line scramble" can mean many different things. If you remember the old TV sets with a horizontal hold control, having that control misadjusted will cause one type of horizontal line scramble, and is also somethng that can occur in a VCR. Another type of "horizontal line scramble", for instance, can happen when there is arcing in the video drum's rotary transformer. In this case, you would see a random flashing of thin, bright horizontal lines running randomly through the picture at irregular intervals. Loss of vertical synchronization (rolling) could also be thought of as horizontal line scramble if the sync is especially faulty - the black blanking bars between picture frames can run by so fast that it appears as a "scramble" rather than a rolling picture. A video, or at least a picture, would be very helpful as each form of scramble I've described is caused by very different things. Does it look like terrible tracking? Can you see any picture at all? Does it come and go? Does it ever clear up, even for a moment? Can you smack the side of the VCR and change it at all? . . . Barry Fone - VCR Repair hobbyist and professional FAA Repair Station Avionics Bench Technician (top level). TEST EQUIPMENT: (4) Sencore VC93 VCR Analyzers, (11) Tentel gauges, Sencore VA48 and (2) VA62 Video Analyzers, Sigma Electronics TSG-375 NTSC/SMPTE Video Generator, several VCR Alignment Tapes, plus countless Oscilloscopes, Frequency Counters, Wow and Flutter Meters, Distortion Analyzers, Vectorscope, 136-channel Logic Analyzer, Signature Analyzer . . . . VIDEO GEAR: (6) JVC BR-S822U's, (3) JVC BR-7000 series, (3) JVC BR-S500U, (2) JVC BR-S800U, JVC GR-800U and (2) GR-860U Editing Controllers, Sony FXE-100 Video Switcher/Effects Generator, (5) Time Code Generator/Readers, (1) Sony SLO-1800 (Beta), (2) Alesis ADAT-XT, (1) Sony DXC-1200 TV Camera, Pioneer VP-1000 Laser Disc Player plus many consumer grade Beta and VHS VCR's. Passionate electronics enthusiast since 1973...most anything except computers. Check out my collection at www.barrys8trackrepair.com/MyVideoGear.html
(This post was edited by Barry777 on Mar 13, 2010, 2:20 AM)
