trips51
Apr 15, 2006, 1:56 PM
Post #4 of 8
(3082 views)
Re: [wwf20112] vcr help (sanyo)
I have worked hard on this issue, we have over 850 of these in use. Sayno src-800/src-850. So far I have found the problem to be in the motherboard! When the unit gets around 2yrs. of 24/7 use, or 15,000 to 20,000 hrs of record. You will get a color band on playback of Re-Recorded tapes. First records on new or demagnitezed tapes will be clear. I have swapped out the complete chasy unit with and New vcr, the problem stayed with the orig. one. Atemped adjusting vr111 "no change". The only answer I can give at this time, Erase the tapes for re-recording. *NOTE- Removing the video head and cleanind the coils of oil and flux will help clear up some grainy/noise in video. Hope this helps, maybe someone can go with it from here.
