Rak01
Dec 12, 2007, 10:46 AM
Re: [techchris] Ferguson icc17 chassis
Hi techchris, I disconnected the ribbon cable from the 9 pin socket which feeds the channel/vol up/down assembly. this cable also feeds the infra red receiver on the same pcb. On examination 4 pins go directly to 4 tact switches which appear to function correctly. The remaining 5 pins feed the infra red receiver associated circuitry. On reassembly the set behaves as before. i.e. Turn on via on/off switch. LED goes red and immediately goes to yellow and then green without the use of the remote. Set then begins to cycle AV1,AV2 etc. Whilst on AV1 perfect picture momentarily until set switches to AV2. Set responds to remote when switching to standby, set switches off with red LED, which then goes yellow by itself and cycle starts again. I would appreciate any further suggestions. RAK01
