dkdhas3
User
Sep 24, 2008, 7:22 PM
Re: [kpayton] someone Please help
i may be alone here but the MM series is one of the most pain in the ass tv's ever made. there are a few common problems with that model.the most common one involved a slew of parts including surface mounted diodes and resistors and a reg. ic if i'm not mistaken. from memory and its been a while for this set the board on the left if your looking at the back , if you can get to the underside of it you can see a large charred area in the center. i used to cringe when one of these came up. i could be way off, but the control board are the buttons in front maybe is what she is talking about and that is prob. not the probl.if you can see the burned area in the center of that board, and you can do surface mounted soldering and have a lot of beer, time and curse words, i will dig up the info. good luck
