Red Static?
Biliouschee
Feb 10, 2007, 5:07 AM
Post #1 of 6 (8149 views)
Red Static? Can't Post
I've noticed that when my plasma TV (Toshiba 42HP66 42") goes to a black picture (and sometimes color), there is some red static. its really obvious and annoying at times when there's a lot of black on the screen. It appears more while watching TV than movies (I use digital cable/HD tv from comcast) Is this fixable or common on plasmas? Need i worry?
MOtvGuy
Feb 10, 2007, 4:38 PM
Post #2 of 6 (8147 views)
Re: [Biliouschee] Red Static? [In reply to] Can't Post
You've got a problem on the Y sustain board. If the set is still under warranty you need to get a servicer out to fix it.
Feb 10, 2007, 5:05 PM
Post #3 of 6 (8145 views)
the sustain voltage is adjustable on the powersupply.usually there is a label on the back of the screen to tell you what it should be for that screen
mikemaiertv
Mar 4, 2007, 10:36 PM
Post #4 of 6 (8109 views)
Theres a reason why you should ask a autherised Toshiba repair center, cuz if you don't you get Y board failers and power supply problems or you could just read the atatched service buliten
Now keep in mind this is only for this chassis of Toshibas So all the rest of you with the Vizio and the Samsungs look elsewhere for a solution
(This post was edited by mikemaiertv on Mar 4, 2007, 10:39 PM)
Attachments: LVSD.pdf (164 KB)
Biliouschee
Mar 5, 2007, 7:51 AM
Post #5 of 6 (8103 views)
Re: [mikemaiertv] Red Static? [In reply to] Can't Post
I had a TV tech come out and he's repairing it. He's replacing the inside (i think he said something about the actual plasma, im not sure) but i also have a dead pixel, but he cant fix that because toshiba's warranty only covers dead pixels if there are 3 or more...
denonjapan
Mar 13, 2007, 8:29 AM
Post #6 of 6 (8087 views)
None of the answers your received here ever came close to the problem, You can't fault the display if the input source varies from the other that causes this statics. There's no such thing!/ check your power source, if problem still exist, call COMCAST and have your HD BOX replace. Your plasma is fine to me according to your description of the problem.
denonjapan
made in japan
