Darkish Picture
bogart219
Oct 20, 2009, 11:51 AM
Post #1 of 18 (3059 views)
Darkish Picture Can't Post
Yellow again,
After I switched hyperboards, the picture on my set (57hdx82) appeared to be fine. Now for some resaon the picture looks to dark. I have a high definition cable box hooked up to colorstream 1 and a dvd player to colorstream 2 with component cables. Its the same in standard def as well as high def. The picture (in high def ) looks like it is real clear just darkish. I cleaned the lenses before my hyper repair. I tried turning the settings up in the menu for contrast and brightness but it didn't seem to make much of a difference. If I got into the service mode, are there settings in there that I could tweak to get my picture brighter again? Thanks!
Oct 21, 2009, 2:32 AM
Post #2 of 18 (3052 views)
Re: [bogart219] Darkish Picture [In reply to] Can't Post
Try the Screen (G2) controls first.Wink
bogart219
Oct 21, 2009, 11:07 AM
Post #3 of 18 (3047 views)
Re: [jts1957] Darkish Picture [In reply to] Can't Post
Hi jts,
It seems like the first few days after I swaped hypers, the picture was fine. I did notice that my Ant 2 input is not working. Wonder if this is related? By G2 you mean screen VR right? Would a hyperboard going bad cause the screen to be darker? Thanks!
Oct 21, 2009, 4:40 PM
Post #4 of 18 (3044 views)
You should already know that answer - from your own experience - it can kill picture, raster, etc.Wink
Pg. 8 of SM.
bogart219
Oct 21, 2009, 5:55 PM
Post #5 of 18 (3039 views)
Tried g2 controls, didn't seem to make a difference. Your right about that hyperboard, it might be on its way going out. Might be time to send it out for recap.
bogart219
Oct 29, 2009, 8:32 PM
Post #6 of 18 (3019 views)
Picture still on dark side. It seems clear but maybe not completely. After I put this last hyperboard in, the picture might not of been fine. Wife said she thought picture wasn't as bright before I started all this. I tried that touch focus button on the front and it came back with a touch focus error. Does this indicate my STk's need replaced?
Thanks!
bogart219
Nov 2, 2009, 12:55 PM
Post #7 of 18 (3009 views)
Do you think my touch focus error is related to my darkish picture?
bogart219
Nov 11, 2009, 1:46 PM
Post #8 of 18 (2996 views)
JTS1957,
When we were troubleshooting my set you had me turn up and down the G2 pots (top ones) on my set.
I did mark them with a sharpie before I moved them.
I'm still having trouble with a dark looking picture. After reading scores of post on different forums, people have said that you should never move these cause once you do you screw up the greyscale on it. Do you think this is what happened to mine? Before messing with the set my contrast was on 50 in setup, Now I have to put it on a 100
to watch it and even on this setting the dark scenes on the picture are still way dark. What do you think?
Nov 12, 2009, 12:03 AM
Post #9 of 18 (2994 views)
I think you should judge gray scale by tuning in a black & white TV show (or possibly turning color level to zero) and running contrast and brightness through their range. At all "usable" levels, picture should NOT have a color tint to them.
bogart219
Nov 12, 2009, 12:33 AM
Post #10 of 18 (2991 views)
I did this and didn't see no color. Does this indicate the gray scale is ok?
Nov 12, 2009, 12:40 AM
Post #11 of 18 (2989 views)
The hardest thing for any color TV to do is reproduce a black and white picture at all usable levels of brightness and/or contrast. If yours passed, then its gray scale is fine.
bogart219
Nov 12, 2009, 1:01 PM
Post #12 of 18 (2979 views)
Thanks JT,
At this point I'm sending this latest hyperboard in for repair. I'll post back in a couple of weeks if there was any change. Thank You!
mrhenrybell
Deleted
Nov 14, 2009, 12:16 AM
Post #13 of 18 (2959 views)
Post deleted by Administrator [In reply to]
bogart219
Nov 14, 2009, 2:55 PM
Post #14 of 18 (2953 views)
Re: [mrhenrybell] Darkish Picture [In reply to] Can't Post
Henry, How much does that site pay you for referrals?
bogart219
Nov 27, 2009, 1:22 PM
Post #15 of 18 (2934 views)
Well I sent the hyper board out and had it recapped. Put it back in and still have the same problem, a darkish picture. I have to turn the contrast up to 90. Any thing else to check? Thanks!
Nov 27, 2009, 2:23 PM
Post #16 of 18 (2931 views)
Suggest reading the Service manual pages 10 thru 13.
A few things you can try, just be sure to "record" original values.
bogart219
Nov 27, 2009, 7:52 PM
Post #17 of 18 (2925 views)
Will do. happy belated turkey day!
bogart219
Nov 29, 2009, 1:01 PM
Post #18 of 18 (2915 views)
JTS, You were right again. It was the G2 knobs. When we were troubleshooting the set, I marked them with a sharpie. A little bit of movement made a big difference. When I checked them the first time from your suggestion early in this post, I started out just turning up the red knob, which made the picture reddish. I stopped there for some reason. While watching the tv yesterday and thinking about the problem I light went off in my head. Maybe I should try turning all three up and see what happens. Duh, That took care of the problem. Pictureis good again.
Once more thanks for all your help and patience!!
