cdoublejj
Mar 11, 2012, 4:50 AM
Post #52 of 55
(7254 views)
Re: [cdoublejj] ITC222, RCA D52W20
I'm still alive I was just in a coma after the shock i got from that fly.... okay okay maybe that isn't funny I assure you I'm safe and sound and take care not jolt my self. So I have let the Tv project sit for a while but, have been thinking about again. I have power to the mail 3 CRTs and no sound or picture that means the problem is from the signal or even convergence boards? not sure if the convergences is needed for picture but, i know it isn't needed for sound. so guess some things to check would things like weather or not there is power to the signal boards and convergence or if they have the correct amount of power. perhaps the connectors to the signal boards need reseated or perhaps the signals boards have a cold solder joint, i could re flow the solder possibly not sure if that works with through hole mounting like it does BGA. although the signal boards do have surface mount chips though not BGA.
