Feb 11, 2015, 8:58 PM
Post #30 of 30
(4906 views)
Re: [tom v] Quasar RPTV SR4500EK
tom v;.... The CRT schematic you posted on Photobucket is NOT very clear... My copy of the schematic is NOT clear & it looks like the collector of Q1409 & Q1403 are tied directly together... Would not make any sense as the voltages on the 2 ARE different.. There are some resistors that I would like you to check... I can NOT make out what their reference numbers are... Lets start with the resistor OR coil that comes off the collector of Q1403 (Output)(I'm guessing its 18 ohms or ??) & goes to another resistor that goes to the cathode of the CRT... Also check the resistor that goes from the emitter of Q1406 to ground.... Looks like it might be 4.7 ohms... 3).. I'll need DC voltage readings (E,B,C) on Q1403 , Q1406 & Q1409 ??? I want those readings with the TV ON & video playing... (Antenna , Cable or ???) The NEXT time I ask for info , PLEASE GIVE IT !!!!... I WILL be the one to analyze the info you give... .5 ~ .7 of a volt CAN make a difference... PLEASE TAKE & POST EXACT READINGS... Even IF they are "quirky"... .. THANKS... Later...Ron.M... .. Veteran & Retired TV technician
(This post was edited by Ron.M on Feb 11, 2015, 9:06 PM)
