Mar 14, 2010, 9:02 PM
Post #25 of 47
(5143 views)
Re: [buffalocomputer] CTC167R Pincushion problem
buffalocomputer;.... THANKS for the GREAT pix.... Are we having a problem ("maybe" Alzheimers.. ..).... RE;=>...... When you get the control installed for the pincushion & adjusted , PLEASE take a pix WITH video & post it.... <<EXCELLENT JOB !!! AND pix's of the chassis as earlier requested... << Alzheimers , right ???
OR "memory lapse" or back cover is on , or ??? Needed BOTH !!! I only have a cheap multi, so cap checking is basic... I did the ohms check, started at infinity, raised gradually for a sec. or 2 then back to infinity. That is NOT the way to check caps , especially electrolytics !!!!!... ... ALL that does is tell you the cap is able to charge up...That's IT ... .... I have 2 cap meters , 1 for ESR (The one below) & 1 for value....Both cheeeep !!! One of the best ways is to get a cheap ESR meter.... .... Suggestion;=>... http://matelectronics.com/...L_2d3333#aMUL_2d3333 It's cheap & basic , but it gets the job done... IF you decide to get it , I'll give you some important advice on how to use it.... For now , just go to your local parts store & buy a 47 mfd @ 35 vdc (or 50 vdc if they don't have a 35 vdc cap) cap & replace it.... Also check on the number on the vertical IC....Is it the same as what's in the manual ??? Thank you.... .... Later...Ron.M.... .... Veteran & Retired TV technician
