Sep 16, 2009, 10:56 AM
Post #10 of 32
(3655 views)
Re: [nobleman] hitachi resistor
When you fix you have to find these things out. R941 well that sounds like its in the power supply, Is it off a transformer? the other end, does it feed a diode? Does the diode test short. Resistors dont go short Diodes and Ics do and the odd capacitor. What does the set do without that resistor, Does it feed the vertical , can you run along the print from the diode and see where it goes. That is how you fix, not saying resistors around it look OK. If I am correct and its an LT line from the supply, chances are it feeds the sound with 24 odd volts and the sound IC is faulty. But thats a guess
