Coolant problem?
DaveMN
Apr 6, 2014, 1:17 PM
Post #26 of 67 (1932 views)
Re: [Ron.M] Coolant problem? [In reply to] Can't Post
Sorry for the delay and I appreciate your patience. How does this Tues or Wed sound?
Apr 6, 2014, 5:16 PM
Post #27 of 67 (1923 views)
Re: [DaveMN] Coolant problem? [In reply to] Can't Post
DaveMN;...
Just to refresh both our memories;=>...
That is kind of a "generic" method for Magnavox/Philips TVs..
There are some differences that I would like to suggest to you to make things go better..
When you are ready to jump in & start this , post a day ahead & I'll give you the changes step by step to make regarding the procedure they gave you...
Examples are;...
You disconnect & take out ONLY 1 CRT at a time...
Will explain when the time comes..
Cleaning the lens assembly will be different & EASIER !!...
Will also explain when the time comes..
I will need a pix (NOT HUGE) of the CRT lens assembly...<<
Re-read post #20...
Do you have the stuff you need ???..
I need to know what time zone you live in...
Here's the plan;...
I intend to be online while you are doing this...
Reason is that I'm going to give you 1/2 of the steps & then you STOP ...
I need pix of the 1st (Blue) CRT when it is out of the TV...
I need to see what the lens assembly looks like to give you proper instructions how to disassemble that to clean the lenses & CRT face , etc.
That way you should be able to do it all at one shot instead of a 2 day affair..
This is important...
I have prepared a version of the tutorial that should make some of it easier for you , but , I NEED a pix of the CRT assembly so I can tell you an easier way to clean the CRT face & the lenses...
I intend to give that to you in real time so as to not delay your work & in case there's any glitches..
At the risk of being redundant;=>...
NEED this info...
Reason is:=>..
I intend to be online while you are doing this... & ..
Tues or Wed looks OK at this time..
Contact me Monday for times etc to get this set up & further instructions...
Later...Ron.M...Cool...
DaveMN
Apr 7, 2014, 12:59 AM
Post #28 of 67 (1915 views)
I will take the requested pics tomorrow and reply with them. I will be picking up all the stuff noted tomorrow as well. Tues Or Wed works for me from 9am - 1pm central time.
Apr 7, 2014, 2:03 AM
Post #29 of 67 (1912 views)
DaveMN;....
NO pix YET !!!!
The pix should be taken when you get the BLUE CRT OUT of the TV...
I will give you instructions tomorrow...
It should be about 11:30 Mondy morning...
Later...Ron.M....Cool..
DaveMN
Apr 7, 2014, 2:04 AM
Post #30 of 67 (1910 views)
Sounds good
Apr 7, 2014, 6:16 PM
Post #31 of 67 (1906 views)
(This post was edited by Ron.M on Apr 9, 2014, 6:04 PM)
DaveMN
Apr 8, 2014, 12:02 PM
Post #32 of 67 (1894 views)
Got my morning coffee and will be starting momentarily.
DaveMN
Apr 8, 2014, 1:51 PM
Post #33 of 67 (1890 views)
Im stuck on understanding this part..
IF you CAN , in the 3rd pix in this step , there's a small yellow slot on the side of the flyback that has another slot 180* from this one...
DaveMN
Apr 8, 2014, 3:47 PM
Post #34 of 67 (1886 views)
Got my tv dismantled and just am hung up on clarifying step 2. If a phone call would help Ill be more than happy to call or vise versa.
Apr 8, 2014, 4:24 PM
Post #35 of 67 (1880 views)
DaveMN;....
I'm on slloooowwww dialup & can't be online & the phone at the same time...
What is the problem on step 2 that you need help with ???..
Where exactly are you stuck ???
DaveMN
Apr 8, 2014, 4:55 PM
Post #36 of 67 (1874 views)
Im not wraping my head around what you want me to find exactly.
Apr 8, 2014, 5:05 PM
Post #37 of 67 (1868 views)
DaveMN;....
"They/I" want you to trace the heavy red wire that comes off the side of the "Blue" CRT to the flyback & remove that wire from the flyback...
Follow my instructions for removal & NOT theirs...
IF you get stuck there post back & I'll give you an alternative way to remove the wire...
Just pulling up on the wire without releasing the tabs can & often does cause damage to the flyback...
Does that help ???
Later..Ron.M...Cool..
DaveMN
Apr 8, 2014, 5:11 PM
Post #38 of 67 (1865 views)
did it moving on
DaveMN
Apr 8, 2014, 5:20 PM
Post #39 of 67 (1858 views)
lost again.. "In pix #9 , it may be easier to disconnect the black wires at the top of the CRT from the shield...
Your call on this one.. "
DaveMN
Apr 8, 2014, 5:22 PM
Post #40 of 67 (1856 views)
nm got it moving on
DaveMN
Apr 8, 2014, 5:28 PM
Post #41 of 67 (1851 views)
cant remove board
Apr 8, 2014, 5:30 PM
Post #42 of 67 (1849 views)
DaveMN;....
According to my clock & your time zone , it's 12:30 at your location...
It doesn't look like you're going to get both tubes done today...
How much time do you have left for today ???
DaveMN
Apr 8, 2014, 5:32 PM
Post #43 of 67 (1848 views)
got it off but the white and blue wires attached to the detached board
DaveMN
Apr 8, 2014, 5:33 PM
Post #44 of 67 (1845 views)
as long as it will take
DaveMN
Apr 8, 2014, 5:34 PM
Post #45 of 67 (1842 views)
is it ok that the blue and white wires are still attached to the detached board?
Post #46 of 67 (1840 views)
DaveMN
That's OK...
The board stays in the TV...
Later...Ron.M....Cool...
DaveMN
Apr 8, 2014, 5:42 PM
Post #47 of 67 (1832 views)
stuck on pix 4. the instructions sat to "On each tube you will find "4" small screws that hold it to the metal rack. The screws will be located on the outer edge of the square tube frame. Remove all four screws on the blue and green tube. Do not remove the screws on the lens cap."
DaveMN
Apr 8, 2014, 5:46 PM
Post #48 of 67 (1829 views)
I see no need for you to be online. can you save these pages any anything else offline so I can give you a call to move things faster?
Apr 8, 2014, 5:52 PM
Post #49 of 67 (1827 views)
DaveMN;...
Look in the area with the blue circles for 1/4 hex head screws...
Follow MY instructions in post #31..
I've added a new pix...
EDIT:...
Be SURE you MARK EVERYTHING YOU DISASSEMBLE BEFORE you take it OFF !!!
Later...Ron.M...
(This post was edited by Ron.M on Apr 8, 2014, 6:00 PM)
DaveMN
Apr 8, 2014, 5:54 PM
Post #50 of 67 (1826 views)
I took the screws off so the tube is not attached to the mental frame but the bottom part of the tube is still attached
