Dec 18, 2010, 8:02 PM
Post #68 of 84
(2564 views)
dgentry516;.... OK .....Lets review these one by one.... Look for bold comments as I'm not going to insert a ton of quotes..... From your post;.... Quoted from my post #62;... You said, "With the TV UNplugged , go to D621 , D624 & D625 & read ohms to chassis ground...Post readings... " "With the TV plugged in , check for DC volts at all these points;=>.... D621 , D624 & D625 again....(To chassis (Tuner) ground)...Post readings.... " (So far , so good) The next answer to this is in post #63 which is;=>.... D621 Chassis - band end 4.72k and dropping D624 Chassis - band end 19.xxM and dropping D625 Chassis - band end 19.40k and dropping I assumed that those ^^^ readings were from the diodes to "tuner ground , i.e. chassis ground.... Again , so far so good.... Then you added this;.... From my post #64;.... You said, "Me thinks you did not switch grounds here.... MY bad.... This reading is on the AC side....<<My bad , poor choice of wording here... ... Right church , wrong pew !!! You needed to connect to the AC HOT ground....<<Ditto... ... I should have put that info in the post....SORRRRY !!!...... Re-read it & post info... " That comment was & is limited to Q601 ONLY..... Then you said from post #65;.... I said, D621 19.85 to HOT ground D624 19.32 to HOT ground D625 19.27 to HOT ground Q601 base to HOT ground -78.6 (plugged in) No change when power button pushed. D621, D624, D625 no voltage. dc measurement from diode to HOT ground This is where things got both of us confused...(I THINK ).... I did not ask for any readings from D621 , D624 or D625 to "HOT" ground....Will explain shortly.... I understood this to mean….With the TV UNplugged , go to D621 , D624 & D625 & read ohms to the AC HOT ground (black power cable)… <<<<Going to clarify this in a bit !!! D621 19.85 to HOT ground (ohms) D624 19.32 to HOT ground (ohms) D625 19.27 to HOT ground (ohms) With the TV plugged in , check for DC volts at all these points;=>.... D621 , D624 & D625 again….to the AC HOT ground (black power cable)...Going to clarify this .... D621, D624, D625 no voltage. dc measurement from diode to HOT ground At this point , I'm going to skip ahead to>>> You said, "Lets check the base of Q601 , read dc volts…" I said, Q601 base to HOT ground -78.6 (plugged in) No change when power button pushed. You said, "You should be getting about +170 vdc on the center pin of Q601.... IF you get -78.6 vdc with the set plugged in & the black lead is hooked up to the negative side of C609 (The fat 470 @ 200 vdc lytic) , that suggests that Q601 is bad..... " The center pin on my Q601 is the collector. The vdc from the center pin (collector) to the negative side of C609 is…. +174 The negative side (black power cable) to the base pin is -78.6 The negative side of C609 to the base pin is 0. HERE:... Did I miss something? Maybe.... I'm going to fall off the wagon if I keep making mistakes. << Please don't land on me .... ... Let me know if you still want me to …Yes , but , first....Go to the explanation below >>>>> Unplug the TV & let it set for awhile....(About 5~10 mins) Short out C609 (Thats the plus to negative on the cap..... There may be a hefty spark... Remove Q601 & check it (Use ohms) & post readings (numbers).... Check;...R613 & R618...Post readings.... Thanks Ron Lets clarify this "ground" confusion.... Look on the bottom side of the board for a heavy white line that looks like a boundry line & encloses an area.... On some Sanyos , inside that area somewhere is the word "HOT" printed in white letters.... Outside that area somewhere else in white letters the word "Cold" is printed... All parts & readings that are inside the "HOT" area are checked there with the black lead hooked up to the same point that the negative side of C609 is connected to... This also is loosely refered to as the "HOT" AC side or "HOT" ground.... Outside the white enclosed area is known as the "Cold" ground & "chassis" ground.... ALL parts & readings are taken from the part to the "tuner" case or similar places that I have not yet told you how to find.... The "Black" AC wire is NOT used for any purposes that would help us.... It is NOT a bonefide ground connection.... Lets verify this by connecting a meter lead from that "black" AC wire to the negative side of C609 & see what your meter reads.... It should read about 1.5 M ohms... Then go to the tuner case from C609 & see what you read there.... Hopefully , the ground terms as clear as water... Drinking water that is , not septic.... .... So , please go ahead with those readings & add this as a last item to check;.... AFTER you read R613 & R618 , read ohms from the base of Q601 on the board to , wait for it......Hot ground..... Post all readings while I search for a margarita.... .... .... Now that this ebook is written & I have carpel tunnel syndrome , its your turn to have fun...... ..... Later...Ron.M.... .... Veteran & Retired TV technician
(This post was edited by Ron.M on Dec 18, 2010, 8:09 PM)
