vcand
Nov 7, 2010, 3:08 PM
Post #56 of 56
(1832 views)
Here we go again Yes I know, lots of fun!!!
IF you mean the "kinda" similar and looks like an older board" The "kinda" board, was actually identical; it was older, looked a little aged, and had some caps and stuff that looked different but had the same values. That is the one I used to fix it, and it worked. The newer board, well, is identical but the plug is slightly different, so I will swap the plug out. I looked over all aspects of the board and EVERYTHING (plug aside) is identical. (he sent 2 because he wasn't sure which one was right. they are both ITC222 chassis from RCA 52") Thanks for the part number, I'll contact them on Monday. As far as the coolant leak, none on the boards. I will give RCA credit on that aspect, it looks like they planned on eventual leaks and have a drip pan and plastic wall to catch the fluid.
