Sep 23, 2010, 2:31 AM
Post #28 of 28
(1611 views)
Re: [dumpster] panasonic tv CT-27D11E
dumpster;..... i know now the contrast is the level of white. and brightness is the level of black. Contrast affects both the white & black parts of the pix , hence the name;.."contrast" Brightness primarily affects the "white" part of the pix , hence the name "brightness" raised the level of brightness from the knob on the flyback transformer and all it did was put a white haze over the picture. If the haze was like a bit foggy , I'd suspect an aged (10 yrs) CRT as going south gradually.... if this is goodbye than thank's so much for your time. Unless there's any more that I or jts1957 can do for you , then we'll see ya around the campus.... .... You are MOST Welcome.... madtech;..... Your advice IS TOTALLY useless & unwanted....Buzz off.... .... Later....Ron.M.... .... Veteran & Retired TV technician
