May 19, 2010, 7:29 PM
Post #89 of 115
(1726 views)
Re: [kingm316] CTC169 Dead set...
knutnhuny;.... jts1957 is correct....I don't have a lick of experience on LCD , Plasmas Etc.... I suggest you be patient with your thread/post & someone should be along to try to help you out.... Sorry , I can't.... ...... jts1957;.... Your set: Late 2000's LCD display. No comparison. Totally different technology.  100% correct!!! This set: 90's three CRT rear projection. ..100% incorrect !!!.... From post #1;=>.. i have an rca tv of model g35302wk and it won't turn on. 35" glass CRT type set.... kingm316;.... Next,we go to U1001 (The big IC to the right of the tuner)...... With the set plugged in & OFF , go to pin #23.... Hold your meter lead on that pin & press power one time..... Read volts..... Unplug TV & wait or safely discharge 140 vdc.... Plug TV back in.... Go to collector of Q4302 (Horiz Driver Transistor).... Read volts.... Hold your meter lead on the collector & press power one time..... Leave it there for a bit & count how many times the volts changes.... Read volts..... Post all readings..... See below pix for location of Q4302... Also , just to the left of Q4302 is T4301.... That is the Driver transformer for Q4401 (Horiz Out Transistor).... Check & resolder Q4302 & T4301 pin connections.... Check & resolder flyback pin connections also.... Post results....
THANKS.... ..... Later....Ron.M.... ..... Veteran & Retired TV technician
(This post was edited by Ron.M on May 19, 2010, 7:32 PM)
