Dead Sony KV-32TS36
First page Previous page 1 2 3 4 5 6 7 8 Next page Last page  View All
Mar 17, 2014, 1:22 AM
Post #126 of 198 (3115 views)
Re: [Ron.M] Dead Sony KV-32TS36 [In reply to] Can't Post
It's infested. Time for last rites.Pirate
CRT_Fan
Mar 17, 2014, 3:50 AM
Post #127 of 198 (3112 views)
What do you make of this?
Old flyback has this number on it: 1-439-498-71
Maybe it is cursed...
Mar 17, 2014, 4:22 AM
Post #128 of 198 (3104 views)
Re: [CRT_Fan] Dead Sony KV-32TS36 [In reply to] Can't Post
CRT_Fan;....
What do you make of this? ..
How come you didnt see that weeks ago ?????...
Monday I'll do some research & get back to you...
mel & jts1957;...
You both are probably right...
But as long as CRT_Fan or I are willing to muddle thru , I see no reason to call the coroner...
Later...Ron.M...Cool...
CRT_Fan
Mar 18, 2014, 2:26 AM
Post #129 of 198 (3093 views)
The joints were soldered absolutely flawlessly. If it wasn't a factory job (and I wouldn't rule out that possibility) it sure fooled me! Maybe it was a warranty repair and Sony subbed their own part???
It's looking futile, but I hate giving up and I hate to trash such a great (and heavy) piece of equipment. I guess I'll muddle through a while longer, as long as you're up to it. At least it's good experience. Plus I've got a few parts left.
This is definitely going to be lower priority though and I'm not sure I want to spend too much more money. Unless it's to purchase a full D board somehow. Maybe I can find someone with a similar set who wants to get rid of it and can ship me the boards. Hmm...
Thanks again for all your help, Ron. Just let me know when you've had enough Smile
Mar 18, 2014, 7:54 PM
Post #130 of 198 (3076 views)
CRT_Fan;....
Yes , it is & so do I...
Not having any luck to see IF 1-439-498-71 crosses to 1-453-146-11/21...
Can not find SONY 1-439-498-71...
Found a generic , but will NOT recommend it as it's made by Asti & have serious doubts it would work...
IF you are willing;=>..
Time to put the original flyback back in & see what gives with that one...
Let's give this one last shot & compare what it does to the "1-439-498-71" flyback...
Just for the hell of it , look on the "D" board for the board number....
It should be on a label &/or printed somewhere on the board...
It will start >> "A-1346-xxx-A"
Please post back with that info before you change the flyback...
Thanks...
(This post was edited by Ron.M on Mar 18, 2014, 8:02 PM)
CRT_Fan
Mar 18, 2014, 9:45 PM
Post #131 of 198 (3071 views)
xxx = 112. Found it on the component side of the board. Not sure what that 1-646-715-11 number is. I assumed that was the actual part number for the board but I guess not.
Noticed another possible problem: C501 is bulging. It's connected to ground though so it's probably not a critical defect.
Mar 19, 2014, 1:30 AM
Post #132 of 198 (3060 views)
CRT_Fan;....
1st off;...
I have/had a dispute with an a-hole in another thread...
He goes by the name of "MK"...
He has lost almost every argument he posed...
So now he is acting like a spoiled brat & throwing a temper tantrum...
He now has returned as "fatman24"..
So "MK" = "fatman24"...
The best way to handle jerks like him is to IGNORE him & let Admin ban them PERMANENTLY!!!...
Back to us;...
A-1346-112-A is the correct board for that chassis/model...
So somebody apparently did some subbing with the flyback that I can not verify as correct...
Ahh , but , it IS...
That cap is a filter for +15 vdc that goes to Q503 & IC501...
That cap IS bad & explains why Q503 was getting very hot after a few seconds..
REPLACE that cap with a 1,000 mfd 25 or 35 vdc electrolytic cap....
That cap IS polarized , so when you replace it , be SURE that you get "+" to "+" & "-" to "-"....
Check D502 to make sure it's OK & NOT shorted..
Then turn on the TV & see how Q503 responds...
Leave the replacement flyback in...
Let me/us know what the results are...
THANKS...Smile...
(This post was edited by Ron.M on Mar 19, 2014, 1:32 AM)
CRT_Fan
Mar 19, 2014, 11:44 PM
Post #133 of 198 (2924 views)
Are we back...? That was weird! Definitely not your run of the mill troll.
D502: not shorted
Wired a 1000ufd 200V (that's the best I could do) cap to the board temporarily. Seems to work and the transistor is no longer getting hot.
Also, putting my ground probe on the heat sink did not cause any disturbances that I can detect this time, so that's good.
Something else might be wrong though. The sound still seems a bit unsteady.
I suspect that the other FBT was partially bad which was masking these other problems.
Mar 20, 2014, 12:18 AM
Post #134 of 198 (2916 views)
CRT_Fan;....
Yep !!!!
I suspect he WAS "MK" , even tho he denies it...
That 1,000 mfd 200 vdc cap has to be HUGE...
Let's forge ahead & see what happens...
How is Q591 doing ???
Getting hot ???
CRT_Fan
Mar 20, 2014, 1:26 AM
Post #135 of 198 (2907 views)
Ron, if you visited this thread when it was messed up, I'd recommend running a virus checker on your PC just to be safe. He only vandalized this thread and he put a Flash object on the page. I don't know what it was, since I have Flash disabled, but Flash is a very common vulnerability on the web.
Ran it for 30 - 60 seconds. The squeal is there but after a few seconds there was another sound a lower pitched whirring noise almost but it stopped after a few seconds. Eventually all the sound stopped and I turned it off.
Q591 was not hot but Q503 was! Either something else broke or I just didn't leave it on long enough last time. AHGGGGH !#$%#$!
Turned it back on briefly and the squeal was back. No idea what's going on here.
In other news, yesterday I did some searching and found a few classified ads in other states for people selling identical models. Sent out a few emails and got a reply from one guy who might be willing to sell me the boards from his working unit if I give him step by step instructions on how to take them out. He said he'd think about it. Might be a bit pricey though.
What do you think? Would major adjustments be required or are most of them tied to the CRT/yoke?
If I buy it, should I get the yoke and/or C board as well or just the main boards?
The CRT itself can't be bad, right? Is this a safe silver bullet repair or I am potentially getting deeper into the money pit?
One last question. The service manual covers a lot of different models and there are two D boards. Would they be compatible with the CRT, just different features, or should I insist on an identical model if I go this route? Even if this guy says no, I can probably find someone else eventually this way.
Have a nice night...
Mar 20, 2014, 6:10 PM
Post #136 of 198 (2876 views)
CRT_Fan;....
Admin told me that we were not hacked as I originally thought...
It was NOT a virus or any sort of malware...
For security reasons I can not tell you what he did to screw up the forum..
I did take your advice & ran antivirus scans & they came up CLEAN...
I have 3 antivirus programs...
Avast , which is active when I'm online , SpyBot & MBAM...
Check C503 & D503...
Check both Q503 & Q505 for shorts...
Preferably out of the TV...
Make sure that both C501 & C503 read 1,000 mfd...
I don't see a problem with the CRT at this time.....
How did the pix look before the set went out ???
The "D" boards are NOT interchangeable...
The "112" board is designed for a 32" TV & the "129" board is designed for a 27" TV...
So you'll have width & vertical deflection problems..
You'll have to get the "112" board IF it comes down to it...
You will NOT need the yoke & "C" board with a new/used "D" board...
You should not need to make any adjustments with a "112" replacement board..
Time to put the yoke back on the CRT...
Slide it on to match the marks you made & firmly tighten the clamp..
Do NOT OVERTIGHTEN the clamp...
Did you resolder the pins on IC605 , the 12 volt regulator IC ???
CRT_Fan
Mar 20, 2014, 10:03 PM
Post #137 of 198 (2869 views)
Everything checks out. Also checked R556 & R557.
Still getting +12 and -15 off of diodes.
Q503 base measures .3V and the collector measures 30+V but I guess that's the (8) waveform. Q503 still getting hot after a short period. Also zapped me this last time. Ouch. Why is it getting so hot???
Q505: B/C 0.07V & 2.7V seems normal.
It's been on for weeks. I put it back the first time you said "connect everything except CN107".
Jah mon.
Mar 20, 2014, 10:17 PM
Post #138 of 198 (2863 views)
CRT_Fan;....
I have to run some errands ,so I'll be gone much of the afternoon..
In the meantime;...
With the yoke & the "C" boards disconnected;...
Turn the TV on & go to yoke connector CN107 & read AC volts between pins 5 & 6...
Post reading....
THANKS...
Later..Ron.M...Cool
CRT_Fan
Mar 20, 2014, 10:45 PM
Post #139 of 198 (2861 views)
~ 0.29 VAC, frequency was unsteady but around 600Hz
Mar 21, 2014, 2:39 AM
Post #140 of 198 (2856 views)
CRT_Fan;....
OK , that's a BAD reading x 2...
Go to IC501 , the vertical output IC...
Read dc volts on ALL pins...
There are 7 pins on that IC...
They are staggered...
Some will be "+" , others will be "-"..
Post ALL readings...
600Hz is WAY off !!!...
Double check that & post...
Thanks...
(This post was edited by Ron.M on Mar 21, 2014, 2:43 AM)
CRT_Fan
Mar 21, 2014, 10:50 PM
Post #141 of 198 (2832 views)
Now it's bad x 7!
IC501
1 1.9 good
2 8.5 bad and wrong polarity. checked twice
3 -5.9 bad
4 -8.6 bad
5 -6.8 bad
6 7.6 bad
7 2.0 good
This time the VDH reading was:
2.6 khz
.18 VAC
I looked into a couple of things and found that the Hz reading is based on zero crossings and the VAC is an RMS reading, not a peak-to-peak reading. It's still off though. For a sawtooth 2.8 Vpp I calculate the RMS reading should be around 0.808 Vrms.
I'm holding out hope to get working boards from that guy I mentioned. Talked to him again and I think it's 80% he'll sell them to me. It turns out he'll be in my area in a few weeks and can drop them off, so I'll be able to get the yoke as well at no shipping cost, and he won't have to disassemble the entire thing.
Mar 22, 2014, 12:25 AM
Post #142 of 198 (2825 views)
CRT_Fan;....
1st thing I'd like you to do is cool your jets on getting a replacement board &/or yoke!!!
And , with 95% certainty , I don't think a replacement yoke is needed OR justified !!!..
2.6 khz
.18 VAC
"VDH"=??
How & what with are you using to get frequency readings ???..
IC501 BAD !!!...
Remove it & re-take voltage readings on the board from IC501 PC connections..
Re-check the temp on Q503 & Q591...
How is the "squeal" sounding ??
Did it change with IC501 OUT ???
Pin 2 has a low reading , but , the polarity IS CORRECT !!!
The -13.8 on the schematic is for Pin #3 !!!
Pin 2 goes direct to +15 vdc...
Check C535 (220 mfd) coming off pin 3 of IC501..
Did you use an ESR Meter to check these caps ???...
(This post was edited by Ron.M on Mar 22, 2014, 12:33 AM)
CRT_Fan
Mar 24, 2014, 12:40 AM
Post #143 of 198 (2798 views)
"VDH" should be V.DY
I'm using a Fluke 112. You can download the manual on Fluke's website if you're interested, but it's pretty skimpy. I don't believe it does ESR.
1 1.9
2 12.2
3 12.0
4 -18.3
5 -0.14
6 12.1
7 2.0
Sound wise it still seems off. The squeal is there but there's a lower pitched noise that is very inconsistent. Almost sounds like a motor or fan spinning up and down irregularly. Not sure if that's the HOT or something else.
Neither Q591 nor Q503 is getting hot now.
C535 = 200
Mar 24, 2014, 5:20 AM
Post #144 of 198 (2793 views)
Fluke used to be the Cadillac of test equipment
Mar 24, 2014, 9:38 PM
Post #145 of 198 (2775 views)
mel;...
In my book , they stilll are !!!
CRT_Fan;...
ALL these voltages are OK except;...
1 1.9
2 12.2
3 12.0 <<< Care to correct or re-check??
4 -18.3
5 -0.14
6 12.1
7 2.0
CRT_Fan
Mar 25, 2014, 12:27 AM
Post #146 of 198 (2768 views)
Now it's measuring around 1.5V but it's not steady and it's definitely still positive. It looks to be "VP OUT" so I'm not sure the reading is meaningful with the chip gone.
Speaking of which, I ordered two more.
Mar 25, 2014, 12:49 AM
Post #147 of 198 (2765 views)
CRT_Fan;...
Yes, replace IC501 with TDA8172 & C535 with 220 mfd @ 50 vdc..
One IC is enough unless you are going into the biz ...Wink...
When you get BOTH parts in , go ahead & install them...
Post when you have done that..
Remember the cap is polarized & should match the polarity when you took it out...
Have a great week...Sly..
Mar 26, 2014, 12:48 AM
Post #148 of 198 (2750 views)
CRT_Fan;...
After thought!!
It would be a good idea to replace "C501's" counterpart C503 with a 1,000 mfd @ 25/35 vdc..
Sorry about the hiccup !!!....Angelic...
noah23
Mar 28, 2014, 9:05 AM
Post #149 of 198 (2737 views)
Thanks for sharing some knowledge. Found solution on my Phillips LCD TV display problem. Thanks
http://ny.pe
(This post was edited by noah23 on Mar 28, 2014, 9:08 AM)
CRT_Fan
Mar 29, 2014, 10:40 PM
Post #150 of 198 (2715 views)
1 = 2
2 = 12
3 = -15
4 = -16.3
5 = -1.5
6 = 11.3
7 = 2
Looks pretty good. No heat problems (short test) and sound may have improved.
VDY = .3 Vrms, 7.8khz
