Mar 30, 2014, 3:55 AM
Post #153 of 198
(1611 views)
Re: [CRT_Fan] Dead Sony KV-32TS36
CRT_Fan;....
You must've missed the last line of my previous post, Ron. No , I didn't.... VDY = .3 Vrms, ~7.8khz There's 2 problems with that reading !!! 1)...3 Vrms should be around 3 volts AC p-p.. 2)...~7.8khz , is WAY off !!!.. Should be around 60 cps !!!
Wanna try hooking it all up and see what happens? I'm a bit gunshy at the moment !!!... BUT , IF you so choose , hook up the yoke , leave the "C" board OFF the CRT & see if you can get a better reading from pins 5 & 6 on CN107.. DID you change C535 , C501 & C503 ??? Later....Ron.M... ... Veteran & Retired TV technician
